Export Section to DWG Wrong Block BasePoint
antonio90rodriguez
antonio90rodriguez
Hi everyone,
I have noticed that when exporting a section or elevation from Revit to either DWG or DXF. The base point of the families is not appearing as it should, even though the origin in the Revit family is correct in plan and elevation.
There is no issue though when exporting a plan view.
Any idea why is this happening? Any way to solve it?
Attached are a couple images one from a plan view and one from a section.
_Vijay
1) check with crop region
2) Check with expert settings(Co-ordinates base)
if still the issue existing try to share sample model for inspection.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
