Export .rvt to .dwfx problem
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
benedictusdwiwibowohario
428 Aufrufe, 2 Antworten
Hi Everyone!
From the revit model that is shared with me through BIM 360, I want to have an export in .dwfx file.
When I tried to do this the coordinate systeem (shared) is not exported but the local is. Which cause problems integrating it with another model.
This problem does not occurs while exporting the .rvt model to .dwg or .ifc. This however, mixed up the Revit model ID for each component, which is really important for me.
Does anyone know how to export a .dwfx file with the correct coordinate system?
@Anonymous langan
Best regards,
Ben
Beschriftungen (4)
2 ANTWORTEN 2
Nachricht 2 von 3
You can't export the Shared Coordinates with a DWFX.
Nachricht 3 von 3
This is problematic especially since using .dwfx export from Revit 2024 to Navisworks is being recommended due to the .nwc exporter not being able to recognize a 3D section box, and severely bloating the .nwc file size.
