Export revit hatches in a different layers in dwg
1 ANTWORT 1
Nachricht 1 von 2
ricciTCJPZ
114 Aufrufe, 1 Antwort
Hi everyone. Is it possible in Revit 2023 put borders and hacthes of the families and categories into two different layers? so i can assign different colors in dwg? thanks I appreciate ypur answers.
1 ANTWORT 1
Nachricht 2 von 2
Ryan_GormanKT36T
als Antwort auf: ricciTCJPZ
You could probably achieve this using one of the following settings;
For instance if you did a color override and chose the "Export all properties BYLAYER, and create new layers for overrides"
