Export Revit file and Augin
2 ANTWORTEN 2
Nachricht 1 von 3
S207763
224 Aufrufe, 2 Antworten
I have added the Augin extension in Revit but when I want to export the Revit file I get this message even though the file is very small. Can i please get some help.
"There has been an unrecoverable error during export. This may be because the file is too large to export. Try using filters and "Current View Only" mode, or look at the documentation for more suggestions. Export will now be aborted."
Beschriftungen (2)
2 ANTWORTEN 2
Nachricht 2 von 3
SteveKStafford
als Antwort auf: S207763
Sounds like you should get in touch with the Augin developers and/or review their FAQ and recommendations for exports from Revit. Their site includes this "we suggest that you export your project to IFC 2×3 or IFC 4 format and upload the project using Augin Hub"
Steve Stafford
Nachricht 3 von 3
handjonathan
Hi @S207763
Thanks a lot for posting your question to the forums!   Has the solution suggested by @SteveKStafford helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
