Export NWC from Revit 2015
2 ANTWORTEN 2
Nachricht 1 von 3
patrik.kvirenc
483 Aufrufe, 2 Antworten
I have a problem with exporter NWC in Revit 2015. After the export models in NWC from Revit 2015, I will record and put together in Autodesk Navisworks. But models are scattered and do not sit on each other. But if I make an export in IFC, than everything is fine. If I upgrade Revit 2015 models to Revit 2016 and make an export NWC, than everything is OK. I tried reinstal Revit 2015 and NWC exporter for Revit 2015 and still nothing. Every conditions was settings right while exporting.
Thank you for you help,
Patrik Kvirenc
2 ANTWORTEN 2
Nachricht 2 von 3
Alfredo_Medina
als Antwort auf: patrik.kvirenc
Have you compared the Naviswork's export settings one by one, before exporting from 2015 and 2016?
Good news is that if you already upgraded the models to Revit 2016, you won't need the 2015 exporter any longer. Or do you still need it for other projects?
Nachricht 3 von 3
patrik.kvirenc
als Antwort auf: Alfredo_Medina
Hello Alfredo,
Thank you for your answer. I compared export settings in 2015 and 2016 completely. With a colleague, we compared the settings in the same version 2015.  Him it worked correctly but not me. We absolutely do not know where could by a problem. We still get models in Revit 2015, so I would be happy if an exporter worked correctly. Uprading to new version 2016 take a lot of time.
Have you any other ideas?
Patrik kvirenc
