Export link revit files and main project in one ifc
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
mairh_tsek
291 Aufrufe, 1 Antwort
Hello all,
I want to make some .ifc exportations from my main project using also some links revit files . I noticed that in ifc the link model is not appeared.
I would like to ask you about your experience with this issue. Is it good to use the 'Bind option' in order to integrate the link file in the main project or it is better finally to do 2 different exportations one from each revit project ? Or is there any other way ?
Thank you in advance!
1 ANTWORT 1
Nachricht 2 von 2
L.Maas
als Antwort auf: mairh_tsek
The idea behind IFC is that you export only the part you are responsible for. So normally the linked files are exported by the party/person creating that linked file (to avoid duplicate content in combined IFCs ).
Depending on the size of the files binding can take quite some time and might give conflicts/errors. So I would advise to export each file separately.
In the IFC export there is a setting that can help you with this.
Louis
Please mention Revit version, especially when uploading Revit files.
