I have been trying to do this for a while but cant seem to figure it out. Is there a way to export a revit model to CAD, with each line style as its own layer? Or even to select certain line types and assign CAD layers to them?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
@mbartolucci- the Line category shown above is listing out Line Styles. They're the same thing. The screenshot just happens to only show system line styles. If you scroll down in DWG Export Setup you will find all of your line styles. From there you assign the AutoCAD layer in the Layer column.
