Export IFC Common Pset Parameters with different name
semmarblo
semmarblo
So, I'm exporting IFC files in 2x3 and the builder/BIM-manager wants the parameter names in a special way.
Example; Floors
they want 'Area' to be called 'net area' and 'Gross Area' to be called 'gross area'
Since these are built-in parameters I can't seem to able to map the to the name the builder wants.
Do anyone of you know if there is a way?
I can make the Project Parameters work through both Pset schedules and Pset mapping txt-file, but when it comes to these built-in parameters it doesn't seem to work?!
Rafal.Gaweda
Autodesk Support
Autodesk Support
semmarblo
Hi @Rafal.Gaweda !
Thank you for replying!
After a few investigating hours and discussions with several BIM-managers we landed in the conclusion that it is not possible to map the IFC System parameters to different names - only the parameters that exist in Revit.
Which of course makes sense 🙂
So, the BIM-manager for the project decided to revise the BIM-manual and now allows the System parameters to keep their original names.
