Export ID list and Select by IDs
1 ANTWORT 1
Nachricht 1 von 2
1745 Aufrufe, 1 Antwort
I have a detached model that I've made a complicated selection set in. I want to bring that into the central model.
I think the answer is to Export a List of IDs for the selection set in the detached model, then Select by ID; or maybe there's a clever way to use Ideate add-ins.
Can anyone help me by adding a level of detail to what I think the solution is? i.e. Export IDs and Select by ID (steps to export the ID list?); any drawbacks or limitations to this method you foresee? Or what would a better solution look like with Ideate?
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
should be able to do this quickly with dynamo. :leicht_lächelndes_Gesicht:  Use Clockwork - SelectionSet.element
Element types - SelectionFilterElement, All Element of Type, SelectionSet.element then Element to ID. Then you can export that Element Id list to excel and feed it back into the new file using clockworks other node SelectionSet.ByElements. Yay! Let me know if it pans out.
