export from revit to pdf - export walls with different patterns
1 ANTWORT 1
Nachricht 1 von 2
Shay.Gaghe
210 Aufrufe, 1 Antwort
hi
after exporting from revit i see in autocad that all hatched laying on the same layer with no local color apllied.
what i want to achive is that 1  revit wall type will create autocad blue hatch and  another revit wall type will create a red hatch.
is that possible?
tx
Using Autocad 2018, Autocad Architecture.
Please accept as solution if i solved your problem
1 ANTWORT 1
Nachricht 2 von 2
syman2000
als Antwort auf: Shay.Gaghe
Yes you can do that. When you export, choose this option
