I need export Revit file to Civil 3D, but Revit exports all layers too. How can I export revit model to Civil in one layer and simplistic and preferably in one action?
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Hi @Anonymous
You can try exporting the Revit file to DWG (AutoCAD) and merge the layers into a single layer and then try importing the DWG file to Civil 3D.
Let us know if you have additional questions.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
