export from autocad 3D to revit
2 ANTWORTEN 2
Nachricht 1 von 3
sofia.munaretto
237 Aufrufe, 2 Antworten
hello,
I have a problema to import a 3d model (dwg) in revit. In autocad everything looks ok but if i import it into revit, it says that there is a problem with the geometry. I can see the 3D in revit but only the external wall it miss the internal wall and columns, so if i do a section I am not able to see it properly.
Can someone help me with that?
Sorry for my bad english.
Beschriftungen (2)
2 ANTWORTEN 2
Nachricht 2 von 3
syman2000
als Antwort auf: sofia.munaretto
Can you post a screenshot so we know the problem you are experiencing?
Nachricht 3 von 3
This message?
Warning: Element is slightly off axis and may cause inaccuracies.
Help | Element Is Slightly Off Axis | Autodesk
