Export elevation with decalc from Revit to DWG
6 ANTWORTEN 6
Nachricht 1 von 7
filippo.costantin3HZMT
516 Aufrufe, 6 Antworten
Hi everyone,
When I try to export an elevation with decalc fron Revit to DWG, I can Export all the geometries but I can't show the decalc. Is that a limitation of software or I should change some impostation?
6 ANTWORTEN 6
Nachricht 2 von 7
No can do.
What about DWF? That work for you?
Nachricht 3 von 7
I never used DWF format. I need to export in a format which that can be edit in Autocad as a DWG. DWF format is like DWG?
Nachricht 4 von 7
have you try to export as DXF then in autocad DXFIN in command prompt and see if helps. thanks
Nachricht 5 von 7
I try to export in DXF but I cant' show the decalcs.
Nachricht 6 von 7
i did try to export to dwg, dgn, and dxf but cannot see the decal image in autocad. thanks
Nachricht 7 von 7
Is there any possibility?
