EXPORT DWG VIEW TRUE COLOR? PROBLEM IN AUTOCAD (EVERY LAYER IS BLACK)
1 ANTWORT 1
Nachricht 1 von 2
1208 Aufrufe, 1 Antwort
Hi Guyz,
I've got a little problem with DWG_Exportation: from Revit i Export to DWG 2010 and open the file on Autocad. In Exp_Settings I set at colors schedule True RGB colors because on revit I used a View Template with different colors ( cyan, red, grey...) but when I opend the DWG File into Autocad every layer is Black and Colors of printing too (in particular the solid fill hatches ). So wich is the parameter that I have to change in Revit o in Autocad to have the same colors used on Revit Project?
Thanks for any help.
1 ANTWORT 1
Nachricht 2 von 2
AnnaOscarson
als Antwort auf: Anonymous
If you are using Revit 2017 or previous releases of Revit, the option TrueColor means that is uses the color specified in Object Styles.
If you use Revit 2017.2/2018, there is a new export option “Specified in view”, which uses the color from the assigned material colors of the object surface patterns. This option displays colors that are more true to those seen in the Revit view.
More information can be found here
Hope this helps!
Anna
Anna
QA Analyst
Autodesk, Inc.
