When exporting a DWG from a sheet, shared coordinates are lost even if "Shared coordinates" checkbox is checked in DWG export settings.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Ok thank you for the reply (even if it should be great to be able to export the view placed on the sheet with shared coordinates)
