Hello all,
When I export a .dwg file from Revit and unselect the option 'Export views on sheets and links as external references'
all the links that I had in Revit come in the same position in autoCAD. but the file references dialog in autoCAD is empty.
As I want to have also the file references in autocad, in Revit I check the option ' Export views on sheets and links as external references', the problem is that after the exporting some linked files come in different position in autocad. I tried both make the export with the shared point or with the project base point.
Any idea how can I have in autoCAD all the files in the same place ?
Thank you in advance!
