Export dwg from revit - Crash
10 ANTWORTEN 10
Nachricht 1 von 11
atelier.absinthe
6284 Aufrufe, 10 Antworten
hi, I have already complained about this on twitter, and have been redirected here.
Summarize briefly ...
I have a rvt "master" with 7 linked files.
since I did upgrade to the latest release, whenever that export to dwg, revit crashed.
On another PC not updated the problem no error why? :leicht_lächelndes_Gesicht:
waiting for the new version how can I solve this problem Unpleasant?
Facchetti Davide - www.studiofacchetti.com
Davide Facchetti | Architect | Studio FACCHETTI | Bergamo - IT
10 ANTWORTEN 10
Nachricht 2 von 11
JoAnn_Hogan
als Antwort auf: atelier.absinthe
Hi There,
Do you have all the Revit updates installed yet? There is 5 releases for Revit 2015. You can see the updates in the Autodesk Applications Manager. Please see the attachment.
Alternatively you can see the latest updates by following this link: Autodesk Revit Updates
Please let me know if this helps.
If this post solved your issue please mark as solved and Kudos are always welcome :grinsendes_Gesicht_mit_großen_Augen:
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
Nachricht 3 von 11
atelier.absinthe
als Antwort auf: JoAnn_Hogan
i've installed a Autodesk Revit 2015 Update Release 7 for Revit 2015 R2 the problem persists!! :leicht_lächelndes_Gesicht:
I hope that the new rel. 2016 will not be messed up with the same myriad of updates to this rel. 2015
Nachricht 4 von 11
JoAnn_Hogan
Make sure that your windows updates is installed. Is sometimes happens that when your PC is out of date it is more likely to crash.
What is your PC specs? Note that you need quite a lot of RAM. Autodesk would recommend 4GB of RAM. If you are running a 64-bit you should use more that 6GB of RAM as the 6GB is enough to run your operating system alone. Im not saying this IS the problem, all Im saying is that this might be a cause or culprit of your problem.
Altrenatively you can share your drawing with me and I could have a look at it, but seems like this is quite a big project and information might be sensitive. You are more than welcome to share the model privately with a NDA.
Jo - Ann
Nachricht 5 von 11
atelier.absinthe
my PC is an HP workstation Z420, with 16Gb of RAM, video card nVidia 2000, W7pro 64bit, so I think that is not a problem .... PC prior to now I have never had problems like this ... .
by the way, I also tried with other projects, and the problem returns equal identical, then exclude that the problem can be traced back to the file ... but let me think its a software problem Mann (traurig)
Nachricht 6 von 11
JoAnn_Hogan
Make sure your Direct X and Graphics Card Drivers is up to date. I have noticed that 2015 is much more intense on my graphics (even AutoCAD) than earlier versions.
So heres the link to check: Graphics Card Drivers
Jo - Ann
Nachricht 7 von 11
atelier.absinthe
thanx for your interest but the driver of video card are update too! :leicht_lächelndes_Gesicht:
Nachricht 8 von 11
JoAnn_Hogan
Good Morning, :grinsendes_Gesicht_mit_großen_Augen:
Please try the following: Under "Visibility Graphic Overrides" , "Revit Links" make sure all links are set to "Custom" and the "Detail Level" set to "Coarse"
Please let me know if this worked.
Jo - Ann
Nachricht 9 von 11
atelier.absinthe
G'morning!
I do not know how ... but this morning .... is back to work. Yesterday I did not do nothing wrong and I have not changed anything, not even the video card drivers ....
The solution that I've marked
"Visibility Graphic Overrides", "Revit Links" make sure all links are set to "Custom" and the "Detail Level" set to "Coarse"
might work, but in doing so I lose all the potential of Revit ... for example the filters of visibility set in linked files ...
If the problem will recur let you know if it works properly or if there is a work-around "smarter"
Nachricht 10 von 11
JoAnn_Hogan
Sorry let me just make sure that I am understanding this correctly.
Changing the Visibility Graphics to course worked but you feel that it looses a lot of potential?
Jo - Ann
Nachricht 11 von 11
revitpeon
Typically if you do a DWG export, you'll want to export the Coarse model-- the Medium/Fine versions could have more detail than whatever you're importing it into for e.g. 3D rendering can handle.
For me, installing the latest version of DWG TrueView solved the problem:
http://www.autodesk.com/products/dwg/viewers#
