Export dimensions to excel.
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
Darwin33
570 Aufrufe, 7 Antworten
I have some dimensions with an specific style that I would like to export to excel. Is this possible?
7 ANTWORTEN 7
Nachricht 2 von 8
L.Maas
als Antwort auf: Darwin33
Not sure what you want to export to excel exactly. If it is data then you can create a schedule, export it as .txt file and import that ino Excel.
Other option is to create a Dynamo script, extract the data from Revit and store it in a Excel file
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 8
Darwin33
als Antwort auf: L.Maas
I have placed several dimensions that are not related to specific elements, and I would like to export to an excel list or txt file. I know the procedure to export data linked to families and types, but I am wondering if I can export dimensions.
Nachricht 4 von 8
mhiserZFHXS
I think we may need to understand the "why" here in order to help... I have no idea what you are asking for.
Nachricht 5 von 8
L.Maas
Still not sure what you are trying to accomplish. But here a concept with Dynamo.
Here I extract the dimensions and its value. After that I can build out the script to export those length values to Excel.
Of course you can build it up to filter out certain dimensions or extract other information.
Louis
Nachricht 6 von 8
So you want to export values of a specific dimension type to excel?
Nachricht 7 von 8
Darwin33
Hallo
Thankyou for answer.
We have a  plan view with different dimesions types, ie 8mm height for dimensions between pilars, 6mm dimensions between pilars and other diferent elemets, and I want to export only the dimensions related to a height ie al dimensioins red color wiht 6 mm height.
Nachricht 8 von 8
L.Maas
Here a concept.
In this case I filter all dimensions in a view and then group them by dimensiontype. Then I take one of the of the groups and have all the values of the dimension belonging to a certain dimensiontype.
There are many ways to something similar or expand on it, depending on your needs.
Louis
