Export different design options to a rendering engine
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
471 Aufrufe, 1 Antwort
I'm trying to create three different design options, and render a nice 3D view for each option in a project I'm working on. One with normal electrical outlets and light fixtures, one with outlets and downlights, and one with extra outlets and even more downlights to show to the customer.
Is there any way of showing the different design options in a rendering program? The ones in revit does not work very well because the IFC with the building itself was made in archicad, so all windows and doors have huge yellow boxes around them, and when i try to render inside revit everything turns black..
Can I export each option as a separate ifc, and link them together inside of a rendering engine?
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
Create different views for different design options and set the design option to show correctly for each view (VG > Design Options tab). Export each to IFC with the setting Export only elements visible in view.
