have you try to change the LTSCALE value in autocad file. thanks
@ennujozlagam wrote:have you try to change the LTSCALE value in autocad file. thanks
Thanks for your answer.
We import our dwg into a current one, LTSCALE messes up the current linestyles.
But I guess that it could be a way forward.
It should be possible to make the DWG look as the export in Revit though?
With the same scale and all.
Perhaps you could adjust the Export setting for just that linetype then - see attached.
