I am attempting to export a CAD file from Revit that includes distinct layers. However, I've noticed that the 'Glass' layer isn't being exported separately from the 'Window' category. Can anyone clarify what might be going wrong?
For context, the window family contains nested families, one of which is the glass family with the subcategory Glass.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Because a surface pattern can only be assigned to the main category (Windows), and not a subcategory (such as Glass). If you add lines in Glass subcategory instead of using a surface pattern then the lines will be exported to the correct layer.
