Hello all!
In the project I'm currently working on I want to export an IFC model from a part of the model. For this I use a 3D view with a filter based on a parameter value and a section box to crop the view. In the model there are a couple of areas I also would like to export to IFC. We are running in a problem: when I use a section box no Area are exported. But when I uncheck the section box all the Areas are exported beside the fact that half of them should be filter away. My conclusion: with or without a filter but with a section box no Areas are exported to IFC.
Any thought on this matter? Why are the Areas not exported when I use a section box (same for scope box on/off)?
Already tested: IFC exporter plug-in latest version, check/uncheck IFC setting "export rooms in 3d views", Revit 2019 & 2020, Exporting from plan view, area plan view. With and without a filter.
Gelöst! Gehe zur Lösung
Gelöst von TripleM-Dev.net. Gehe zur Lösung
Hi @Anonymous ,
We are having the same issues when trying to export "selected" Areas through 3D views into IFC (scopebox/sectionbox method). In our case we use the area floor plan view, change the VT to just show areas and then export a different IFC.
This is not ideal specially if you have to do it every level, but it works. We use it as a test for info output in IFC, since normally the whole model is exported.
Rooms and Area's are a issue with exporting to IFC.
Exporting from floorplan (visible items only) -> only rooms/areas intersection cutplan plan will be exported.
Exporting from 3D with export Rooms from 3D -> All or None.
Workaround: Use a 3D, add a project instance parameter to the Rooms "IfcExportAs" (would use a different one from the user families)
For all the Rooms/Area's you don't want to export use as value for the "IfcExportAs" = DONTEXPORT
All others leave the value empty
Ifc export will skip these areas/rooms
I use a own written app to fill the value automatically based on workset visible state in 3D view.
- Michel
Hi Michel,
Good point. We are use the DontExport function with most projects but not on Rooms/Areas.
A small Dynamo script will do the job to fill in the "DontExport" with a click of a mouse button.
It works for me. Not the ideal solution but it's good enough
What did I do: Use "DontExport" for all the rooms/areas I don't want to export. Next I hide all the element in a 3D view (regular hide or filter). Export to IFC with "Export only elements visiuble in view" and "Export rooms in 3D views" checked. Note: do not use a scopebox/section box for hiding elements in 3D. It will work for Rooms but you don't export the Areas.
Thanks Michel ![]()
Hi everyone
There is a simple way that is export the cropsectionbox to SAT --> import the SAT into AutoCAD Architecture --> Export to IFC.
Thank you!
BH Khanh
