Explode command?
Explode command?
Explode command?
Does Revit 2016 have an explode command?
If so then where is it?
Thank you for your help.
RDAOU
@Anonymous
Yes; FIRST you need to select the imported file to be exploded and the explode option will be available on the Modify|FileName tab
PS: are you checking your previous posts to mark the appropriate solutions? otherwise if you will continue to ignore replies after you get them; I am not sure if you will continue to find anyone who would be still willing to help
chrisplyler
You can explode certain imported file types, such as dwg files. You can NOT explode Revit native content.
leipert23
Observer
Observer
Hey all!  I made a short video on YouTube to explain how to explode a Block from Revit in Revit!
https://youtu.be/l9QTGh5LraQ
leipert23
Observer
Observer
Solved! Please see my post above!
veso58S5W
Hi all,
I watched the video, and, yes you solved your problem.
But I couldn't solve mine. Have to emphasize, I use Revit LT 2024.
There is no function, in my Revit LT 2024, BIND LINK. Like that I couldn't finish what your video suggest.
To explain my situation:
I had to import IFC made in other program. It is metal frame, it as it is not dimensionally matching the original structure.
I need to "explode" it in order to move beams and columns, and "match" them in proper dimensions.
Might @ToanDN can suggest something and help?
Best regards.
