Hi all,
I am trying to visualize Revit model in Power BI through ODBC export.
Couldn't find a well-defined method on the internet, nor the YouTube helped well.
Thanks in Advance!!
Really appreciate
When I google Revit model in Power BI through ODBC export then there's quite some links to explore?
Yes, Even tried this method here " Help | Exporting to an ODBC Database | Autodesk" , but Revit crashes and closes abruptly.
Attached below image is SS for the newly created UserDSN as "RevitDb" in Microsoft Access Driver (*.mdb. *.Accdb)
1st step. apart from Revit that I created in System ODBC data source Administrator (64-bit)
But the 2nd step. In Revit if I choose any of the option in ODBC export options - Revit Crashes with error report
