Existing Topography Workflow
I am wanting some advice on the best workflow to get an accurate topography on a site with existing buildings.
The issue is the survey DWGs only have points around the perimeter of existing buildings. Therefor the Revit topography joins these points across the building at ground level. If the building has a basement this is not shown in the topography.
My question is how do you deal with this in your Revit topo? How do you form a basement into an existing topo so your new topo cut and fill volumes are correct?
My current solution is to split the surface around the perimeter of the building, then create a graded region from the site outside the building. From there I edit the topo inside the building, delete any internal points and then change the boundary points elevation to the underside of slab height.
This effectively gives me an existing building pad.
