Existing Door Openings
twallVCXPH
twallVCXPH
When a New door opening is drawn it shows as dashed lines.  But when I change the phase to "Existing" it becomes solid lines.  How do I change it?  I would prefer the lines disappear since it's an opening, but dashed is acceptable.
azad.Nanva
You should open the Manage->Phases and in Graphic Override and Phase Filters tab control all your phase graphic.
Do not override line pattern for Previous Phase under Phase graphic overrides.
RDAOU
@twallVCXPH
Playing around with the Phase overrides will affect the entire model and not just the doors. This is something you do not want to do just to fix the door.
You need to fix those lines in the door family itself, either delete or place on a named subcategory which you can override/switch off in the phased view using visibility graphics
