Hi everybody,
I've been wondering how i can fix this or even if it is possible.
For example, when in a newer phase you place a window on an existing wall, if i turn on the phase filter to show demolished only in the new phase, the existing wall will react and show me the sector in which the new window is going to be installed and thus demolished:
But when i place a new structural column in the newer phase, the existing wall won't show me which sector is getting demolished.
If i join the new column with the existing wall, the existing wall in its existing phase will appear affected by the future column, showing me a void where the future column will be.
And if i leave the newer column and existing wall unjoined, the existing wall won't show this interruption previously explained, but it won't show me the part to be demolished like it happens when you have a nested family in the wall.
Can anybody help me with this? Is there a work around it?
Thanks very much for reading.
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
@Anonymous
You have two options
@RDAOU sorry to bother again buddy,
this works great for the phasing part as it shows me the phase filter on the demolished sector, but i just realize that if i set my phase to see the existing model, the structural beams still appear to be affected by the future new element as previously explained, showing a gap where the future element will be.
Does it ring a bell on how to tackle that?
@Anonymous
if you want an identical behavior to a Door or Window you need to use either of the following:
Edit: However, if you can still use Option 2 from Reply 1 and play with filters to show the gap filled
@Anonymous
More Phasing Filter and Override options you can work with while using Option 2: Column + a Void (I see no issues with the Gap)
