Existe alguma forma de usar famílias do 2025 em versão anteriores no Revit?
1 ANTWORT 1
Nachricht 1 von 2
dado_denerdela
68 Aufrufe, 1 Antwort
Olá ótimo dia!
Consigo de alguma forma usar uma família de versões posteriores em versões anteriores?
Tags (3)
Beschriftungen (3)
1 ANTWORT 1
Nachricht 2 von 2
RC_RVT
als Antwort auf: dado_denerdela
No you can't use a family that has been created on a newer version of Revit in an older version of Revit.
Your best bet would be to either
1. update Revit to the version required
2. redraw the family in the version of Revit that you have.
3. find another family online created in a version of Revit that would work
Is the family complex?
If this works, please mark it as an accepted solution. This helps make the forum a better place.
