Excuse me View range isn't activated . .
PhilvK
Advisor Advisor
PhilvK
I have a 3’-4” high wall and have set the cut plane at 2’-0” above Level 1. The wall sits on Level1 but I cannot get the wall to appear in plan section. Detail level is set to fine and View Template = None. What should I check / correct please?
SteveKStafford
I think you are referring to this condition? The Autodesk help documentation says this:
Adesk Help Writes:
  • Walls shorter than 6 feet (or 2 meters) are not cut, even if they intersect the cut plane.
    The 6 feet (or 2 meters) are measured from the top of the bounding box to the bottom of the primary view range. For example, if you create a wall whose top is 6 feet above the bottom clip plane, the wall is cut at the cut plane. When the top of the wall is less than 6 feet, the entire wall shows as projection even where it intersects the cut plane. This behavior always occurs when the Top Constraint property for the wall is specified as Unconnected.
Steve Stafford
PhilvK
Yep, that's my condition. Thanks!
SteveKStafford
Hah funny, you marked your reply as the solution! Good strategy to improve your stats eh? 🙂
Steve Stafford
PhilvK
Rookie mistake
