Excel to Revit?
4 ANTWORTEN 4
Nachricht 1 von 5
573 Aufrufe, 4 Antworten
Excel to Revit?
I am working on a map, and the map table was made using Excel. Is it possible to import an Excel file into Revit?
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
If it looks like the format attached then you can save as to a TXT or CSV file and create a topo from import using that file.
Nachricht 3 von 5
als Antwort auf: ToanDN
It's a building abbreviation table.
Nachricht 4 von 5
Okay. I thought it was a survey pint file since you said 'map'. So disregard what I suggested earlier.
There are several approaches:
- find some add-ins or use Dynamo to a link Excel table to a Revit schedule (type "excel to revit addin" in google search)
- use datalink to link the Excel to a table in AutoCAD and link the DWG in Revit
- save the excel table to PDF and link it in Revit (2020)
Nachricht 5 von 5
Yien_Chao
i would do a placeholder family inside Revit.
then  create the parameters you need, and import the excel data for each placeholder with Dynamo or Python,
OR create a keynote with those data.
are you gonne use the map for other analysis or objects?
