Whatever is drawn becomes crookd or displays as in 3D when in plan view, also, the stand alone wall at the right of the picture has a warning that is overlping another wall when apparently is not. Please help!!!
Gelöst! Gehe zur Lösung
Gelöst von SteveKStafford. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Do you have any linked or imported DWG that extends too far from the model?
If all imported DWG elements are eliminated then that's my bet too Jeff.
Check to make sure your model is created near Revit internal origin. If not you'll have to move it all closer to eliminate the graphics issue.
Steve Stafford
@JMUNGARRO44D2M wrote:
yes, it has been removed though
Create a new 3d view, turn on Site > Internal Origin, zoom extent and tell us what you see.
I see that, and I turned nothing off nor anything was deleted from the model
that distance is much more than that... 416 kilometers
There you are. How far along is your model (documentation wise: views, sheets, annotations, etc...) and does it have phasing?
not too advanced, there is no phasing
Link this model in a brand new Revit model (auto center to center), move the link approximately to the Internal Origin if needed, and bind / ungroup. This would be your working model for this project.
You'll have to move it all closer to eliminate the problem...
Steve Stafford
That's a pretty common reason. They linked CAD, don't realize it is way off in the distance from origin. Zoom all, start drawing... Important to spread the message that CAD can be BAD
Well, it is important to take a good look at each DWG file you're going to use in Revit to make sure it isn't going to cause trouble.
Steve Stafford
Thank you so much Toan, Jeff and Steve for the explanation to the cause of this issue.
