eTransmit not removing sheets as it should
0 ANTWORTEN 0
Nachricht 1 von 1
bzahurakJJAMJ
470 Aufrufe, 0 Antworten
I'd like to use the eTransmit tool in Revit 2021 to remove sheets before distributing our model. However, eTransmit is not actually deleting sheets when I checked in the Transmitted Model. I have the box checked that says 'Remove Sheets' and tried using the same settings on a sample project model and it worked but not on the model I need it to. Any ideas?
0 ANTWORTEN 0
