Error upon error upon error
Hello
I've installed Revit 2018 (student version) w.o. problems and used for a while and it worked fine.
Then suddanly Revit decided to throw away the rendering library, and then the nightmare began.
I had to uninstall completely and then install again, as repairing/reinstalling didn't do the trick.
I've now uninstalled/reinstalled 3 times, and every time I reinstall, I get more error messages 😮
So the question is now - WHAT do I do???
Is it possible or nessesary to erase something in the folders in order to get a clean install?
Thank you 🙂
Mark.Lancaster
@Anonymous
Have you seen this https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/CloudHelp/cloudhelp/2019/...
Mark Lancaster
loboarch
You may want to consider going through the procedure to completely uninstall Revit and get a clean install on your machine. These instructions are for 2018, but would be similar for other releases.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Jeff Hanson
Principal Content Experience Designer
Revit Help |
