Error: The shared parameter file was not successfully saved
12 ANTWORTEN 12
GELÖST
Nachricht 1 von 13
haydenwse
5171 Aufrufe, 12 Antworten
I was trying to create a new shared parameter in my project and got the following error. "The shared parameter file was not successfully saved"
I am the only user on this computer and have all saving rights.  Any ideas how to fix this?
12 ANTWORTEN 12
Nachricht 2 von 13
als Antwort auf: haydenwse
try saving to a different directory. may be a permissions thing (yeh, I heard you. but, still, Widows may not see it your way. It happens.)
Nachricht 3 von 13
haydenwse
als Antwort auf: barthbradley
I have tried opening different shared parameter files as well as creating new ones.  it just doesn't want to play with that type of file.
Nachricht 4 von 13
"that type of file"? It's a txt file for crying out loud.
What a minute. How are you going about it? Also, a Project can only have one active SP file at a time.
Nachricht 5 von 13
haydenwse
I agree but it must be loaded into Revit.  I cannot open an existing file or save a modified or new file from Revit so regardless of the format any files are useless.
Nachricht 6 von 13
Try troubleshooting by copying and pasting SP content to a different file/different name; load into project/family, and try working with that one.  Also, stick that SP file in the same directory as the project/family (although, that shouldn't make a darn difference).
Nachricht 7 von 13
haydenwse
I cannot get any SP file into the project.
Steps taken
Manage, Shared parameters, create, navigate to location where project file is located, name file, save, click ok, get error.
Nachricht 8 von 13
...you missed 3: Repair, Reboot, Relaunch.
Nachricht 9 von 13
haydenwse
I don't know nothing about repair but I have tried the reboot and relaunch several times.
Nachricht 10 von 13
@haydenwse
You are not supposed to be able to write anything in that folder below.  Choose another folder outside of C:\Program Files|
"C:\Program Files\Common Files\Autodesk Shared\Extensions 2016\Products\Revit"
Nachricht 11 von 13
haydenwse
als Antwort auf: ToanDN
Changed to a different file and got it to save.  It is strange that I have been doing it the same way for years and never ran into this problem before.
Nachricht 12 von 13
Did you not read the very first suggestion I gave you: "try saving to a different directory. may be a permissions thing"???
Nachricht 13 von 13
VascoP
I got the same problem. The file properties were ticked as 'hidden'. if I untick that option it works
