Error: Roof By Extrusion
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
BigPicture045
365 Aufrufe, 5 Antworten
This looks like a basic shape, any clues to why I am getting an error here? I've tried different roof thicknesses and rafter cuts., no luck.
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: BigPicture045
What does the error say exactly?
Nachricht 3 von 6
BigPicture045
als Antwort auf: ToanDN
Well, it seems to like curves better...
This is the message:
Ryan_Hettinger_1-1663978206910.pngO
Nachricht 4 von 6
I get the same error if I sketch your shape in two halves. In other words, mirror 3 lines on the left to make a right for a total of 6 lines.
No problem if I make the middle line segment one line for a total of 5 segments.
Nachricht 5 von 6
e.koehne
It looks pretty straight forward. So, you might try to use the roof by mass face tool.
Nachricht 6 von 6
BigPicture045
als Antwort auf: barthbradley
This is correct. By using the mirror tool I was creating 2 straight lines on the same plane. Using 1 line for the top portion works:
