Error "Revit Worker not found"
5 ANTWORTEN 5
Nachricht 1 von 6
GSCOTT09
570 Aufrufe, 5 Antworten
Good day.
Please can somebody assistant with Revit 2020 issue.
I keep getting "Revit Worker not found" when attempting to open the program. Or the revit starter screen just loads. I have read all the forums I could get my hands on and nothing has worked.
I have uninstalled everything and reinstall numerous times using all the installation methods.
I have checked my antivirus
I have checked compatibility etc of RevitWorker
I have updated my Windows and used troubleshoot
I also have check "full control access" as stated in a previous blog
Additionally I even attempted to download revit 2021. Of which the download failed at the end stating "error 2147024546"
Please can somebody help.
Beschriftungen (1)
5 ANTWORTEN 5
Nachricht 2 von 6
RobDraw
als Antwort auf: GSCOTT09
You'll can get some excellent help over in the Installation and Licensing forum.
Rob
Nachricht 3 von 6
GSCOTT09
als Antwort auf: RobDraw
I have posted on all forums and nobody has been able to help me.
Nachricht 4 von 6
RobDraw
I find that hard to believe.
Good luck!
Rob
Nachricht 5 von 6
GSCOTT09
Please stop replying to my posts if you do not have any solutions.
Thank you
Nachricht 6 von 6
RobDraw
Your post belongs in a different forum. That's the thanks I get for pointing you to the proper forum?
If you've covered all the bases and no one can help, the you're out of luck.
Good day!
Rob
