When I try to download multiple Revit models at once (by clicking the check box next to the models and then selecting "Download source files") from where the models are hosted on BIM 360 Document Management (https://docs.b360.autodesk.com) I get a "Failed to open document" error message when I try to open the locally downloaded models with Revit (both 2018 and 2020). To be clear, the models are downloaded to a .zip folder that I then extract and try to open the models and I get the error stated above.
However, if I download the Revit models one at a time from the BIM 360 website, they open just fine after unzipping. I believe it has something to do with it downloaded linked models and that they are overlapping, but I'm not sure how to work around the issue (as one at a time is not a great option).
Is anyone familiar with this and know how to fix the issue?
