Error: Parenthesis expected after function name
krueger
krueger
Sup with it,
I am currently trying to add a Formula to my schedule with an if-statement.
Ive got:
"Loggia" (a yes/no parameter)
"Area" (the normal Revit Parameter which displays the area of a room)
"Fictional Room" (the column where I want to display the result of my formula)
Why: I want to display the actual area of a room divided by 2 if I uncheck the yes/no parameter ("Loggia") in the "Fictional Room" column.
My if-statement currently is:
  • if(Loggia=NOT, Fictional Room=Area/2, Fictional Room=Area/1)
Revit however states "Parenthesis expected after function name" which I thought I already covered with the parenthesis following "Area/1".
Anyone got an idea how I can make this Formula work in my schedule?
Im using Autodesk Revit 2018
Try:
if(not(Loggia), Fictional Room=Area/2, Fictional Room=Area/1))
If Fictional Room is the Parameter you are applying a formula to, you don't use it's name in the formula. The result of the test is either Area/1 or Area/2.
so...if (not(Loggia), Area/2, Area/1)
...also, I get this error when I have a "-" in the parameter name that I want to use in another parameter's formula (e.g. "Height-Arm"). The remedy is the put the name in brackets in the formula (e.g. "[Height-Arm]").
@barthbradley
You are correct.  The [Fictional Room] needs not be in the equation.
