Error opening Dynamo
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
patrick.loureiro
1897 Aufrufe, 8 Antworten
Hi all,
I have this error when i try to open dynamo. Someone have the solution for this?
I already have installed again the Revit.
8 ANTWORTEN 8
Nachricht 2 von 9
ennujozlagam
als Antwort auf: patrick.loureiro
https://www.dynamonow.com/error-opening-corrupted-file/
Nachricht 3 von 9
patrick.loureiro
als Antwort auf: ennujozlagam
Thanks for your answer.
Unfortunately the error is not when opening a .dyn file but rather by clicking on the icon to open Dynamo.
Nachricht 4 von 9
RDAOU
@patrick.loureiro
Marking the solution gives others the impression that it resolved the issue you are having...in this case it didn't
Which Revit Build do you have installed?
Which Version of Dynamo are you using?
Do you have any packages which you have installed (recently or shortly before this error started showing up)
Nachricht 5 von 9
patrick.loureiro
als Antwort auf: RDAOU
Hi Dr.RD,
Thanks for your help.
I have the version 2019 and 2022 of revit.
Dynamo Core 1.3 and 2.04
Dynamo Revit 1.3.4 and 2.0.4.
Add ins i have only the navisworks export and Bird Tools.
But i uninstalled all revit versions cleaned the regedit and deleted all folders of revit. after i installed the 2019 again without any addins. And the error was the same.
Nachricht 6 von 9
RDAOU
@patrick.loureiro
From what it looks like, you need to reinstall the .NET Framework. After you do run the windows System File Check tool to double check and repair any other corrupt system file. Reboot and try to relaunch the application.
... When you say Cleaned you do mean a clean uninstall following step described on Autodesk's Knowledge Net? This includes Dynamo?
Nachricht 7 von 9
patrick.loureiro
@RDAOU
I reinstalled the .NET framework and i run the windows file check. But it stills not working. If i log in with a different windows account all works fine. Probably i have a issue in my account.
Nachricht 8 von 9
RDAOU
@patrick.loureiro
Clean the %TEMP% folder and retry for a last shot
If the issue persists my only guess would be that the related registry keys under your user account are corrupt and were not properly cleaned when you uninstalled....Did you follow the steps recommended HERE also for Dynamo?
If nothing works ... recreate  a new windows account
Unmark please the solution I will notify admin to **** this to Installation and Licensing
Nachricht 9 von 9
pattipakaram
In my Revit software 2024 version dynamo is not working it is showing some error when I'm opening the dynamo. same as above picture..
