Hello, I am trying to create a new floor but I got this message error each time I try to save it. What should be the solution to avoid that ? thanks in advance
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
What did you do? Did you select the Floor and then try to edit its Assembly? There's nothing wrong with that Floor Assembly as far as I can see. Inspect and resolve Warnings in your Project, then close and re-open Project with AUDIT checked. This should clear out any gremlins.
Hello guys, I copied an existing floor and duplicated to create a new configuration. I tried to resolve warnings and made an audit but I still have same trouble. Do you have more ideas ?
Oh well. Hard to troubleshoot without it. Just a guessing game. Maybe someone will come along with the right guess.
Are you copying an actual floor of the existing type then edit to duplicate? Do one of these instead:
- find the existing floor family type in the Project Browser > Edit Type > Duplicate
- select an existing floor > Create Similar > Edit Type > Duplicate
Toan, the second solution, by creating similar floor worked. (strange by the way). Thank you anyway !!! ![]()
