Error message and Type selector missing
2 ANTWORTEN 2
Nachricht 1 von 3
509 Aufrufe, 2 Antworten
On existing and new projects I keep getting an error message appearing "A Required Resource was unavailable". this happens when opening a new project. it also appears when I select certain options within a project.
Also my type selector has disappeared from the Properties menu,  cant seem to find anything within the trouble shooting about getting this tool added back.
Both of these started happening when I installed the new update. I wanted to install the new update as my wall tags initially didn't seem to pull through when I PDF'd my work sheets.
2 ANTWORTEN 2
Nachricht 2 von 3
L.Maas
als Antwort auf: Anonymous
I would do the following
-Restart Computer
-Disable Hardware Acceleration in Revit (restart Revit to be sure)
-Have look at your graphics card driver (updates?)
-Have a look if one of you add-ins cause the issues (de-install them).
-Reset User Interface (see HERE)
-Consider to return to one of your latest restore points
BTW Which Revit version and which update?
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 3
thanks for your response
I have tried restarting my machine, and checked hardware and it is ok
the last update I installed was Service Pack 2 within the downloads page
I am using Revit 2017
