Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Hello, can anyone help me with a specific issue in Revit 2021, when I try to link a template, whatever it is, with an architectural project the following error message appears: "An unrecoverable error has occurred. The program will now be terminated. All of your recent data has been saved, so there is no need to create recovery files; " But it is not a corrupted file, because I tested it on a colleague's revit and it worked normally, only mine doesn’t even appear on the tab to select the file I want to link, revit already gives this direct error and closes the program. All other links normally work only with the revit link that has this defect. Can someone help me?
Solved by syman2000. Go to Solution.
Solved by ennujozlagam. Go to Solution.
how do you link a template? are you saying assign a view template? do you a add-in installed if yes try to uninstall first and see if helps. thanks
You may need to repair Revit. If repair don't work, you may want to uninstall and reinstall Revit.
