error: invalid data dictionaries
2 ANTWORTEN 2
Nachricht 1 von 3
923 Aufrufe, 2 Antworten
From an other firm I got a rvt file and when I try opening it I get this message:
Invalid data dictionaries.
And then I have to close and nothing happens.
I tried importing it and opening it in all the possible ways even through linking it in 3dsmax...
But nothing helps.
Can I do something or do I have to go to the sender?
I just want to know,
thanks,
Aart van Santen
2 ANTWORTEN 2
Nachricht 2 von 3
vabuk2013
als Antwort auf: Anonymous
Here
https://knowledge.autodesk.com/support/revit/troubleshooting/caas/sfdcarticles/sfdcarticles/Invalid-...
it is claimed that
Status:No issue has been identified and the software is behaving as designed.
Workaround:The model will need to be recovered from a backup that can be opened successfully.
But my 19 backup files did not open! The same  "Invalid Data Dictionaries" message appears.
Nachricht 3 von 3
ennujozlagam
can you try to tick AUDIT before opening the file and see if helps? or share your file so we can check. thanks
