I discovered an error in te conections of tail's sections and the scopebox
Once i modifed the section line or section grips, then the conection is lost.
The only way to restored it, is creating a new section, atached to a scopebox and then drag+ctrl (copy) the section
The sections tails don't atached by itself.
The only way is creating a new one whith ctrl+drag
A Real Mistery
Can you post a screenshot what is happening to your existing section? Are you saying the existing section do not respect the scopebox bounding box once you apply the scopebox to the section?
Almost sounds like Non-Cuttable vs Cuttable Family behavior.
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-3253EFCA-F38F-4086-9A4D-C873D8D04867
I hope this video will helful to understand de situation
