Hi.
I have a Issue with Revit 2018.2 when I try to export to InfraWorks I get error message. When I use Revit 2017 it work to import BUT when I opend the 2017 version of a RVT file in revit 2018.2 and save it as 2018.2 It don´t work to export to Infraworks, I get same error message? Can you help?
Br Martin
Hi @BioEnerMart
Can you post a screenshot of this error message you get?
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Hi @BioEnerMart
I'm checking back on this post. Can you post a screenshot of the error messages and the version of Infraworks you use?
Can you share a model to test if possible?
Try this workaround: Exporting an fbx file from Revit and import it into IW.
See a similar discussion and workaround on this thread
Let us know if you still require assistance. Looking forward to your reply.
Viveka CD
