ERROR Importing Phases from Archicad files
7 ANTWORTEN 7
Nachricht 1 von 8
513 Aufrufe, 7 Antworten
I am an architect using Archicad v20.  I have been trying to save an IFC file so that my engineer can use it for design.  The Demo Phase simply disappears when he selects it.  Can anyone help?
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: Anonymous
Are you on the right Forum?
Nachricht 3 von 8
als Antwort auf: barthbradley
I am trying to get an idea from the revit community if anyone has had this issue and has solved it.  So, yes.  I am also trying the graphisoft forum as well.  But I wonder whether the issue is a user error / setting issue within Revit itself.
Nachricht 4 von 8
Where is the "Demo" Phase?  In Archicad?
Nachricht 5 von 8
Demo is in Archicad.  You can also set up the Existing Phase to show Demo elements in Revit.
Nachricht 6 von 8
Viveka_CD
Hi @Anonymous
Welcome to the community!Smiley (fröhlich)
Which version of Revit are you working on? Can you check if you have the latest updates installed for your Revit version?
Nachricht 7 von 8
Phase Mapping is based on the first and last phase in the template being used to open the IFC.  Are there only 2 phases in the rte?
Nachricht 8 von 8
Yes there are only 2 phases in the original file.  I appreciate your response.  Are you saying that you can't change the phases after the fact?  That the template NEEDS to be set up BEFORE you open the file?
