Hi, I'm trying to import a model from rhino into revit as a massing (.sat file type) but I got the following error:
"This family instance has too many edges. Remove unnecessary geometry or split the instance into multiple instances."
Would appreciate if anyone can help me with this issue. Thank you!
Holy cow! Them a lot of edges for darn sure! I don't think a Revit Pattern-Based Curtain Wall with that much intricacy would work either. Looks extraordinarily "heavy". Probably going to need a bigger boat. CPU that is.
The Error is giving you suggestions. Have you tried them? Honestly, even if you broke it up into segments and got it into Revit, I think it would cause intolerable performance issues.
