Hi All!
I am getting an error while trying to use the path of travel between two points. I have attached a screenshot of my error. Could someone explain why? Thanks!
It's about 266'. But, I tried placing the node points just 12' apart and it still gave the same error. Do you have any idea why this would be happening?
Crop the View.
BTW: Same result here with 266 feet. Uncropped View errors out. Cropped View works fine and dandy.
@ahirani24 wrote:
Hi All!
This is a rare case when Revit error message actually tells you very specifically what to do. Do it.
@yes_and_no wrote:Isn't it by code POT is only 200ft max ?
If that's the case, then my "code" must be broken. ![]()
I'm over a mile so far...and still going. My time sucks though. Guess I'm a little out of shape. he, he.
No.
1. In Revit, you could create a path of travel from one train station to the next if you want.
2. Code wise, there certainly are occupancies allow more than 200 feet max POT.
@ahirani24 wrote:
@ToanDN I'm sorry for being so naive. But, I can't crop the view in my situation. I'm working on a model and I will have lots of places where I have to calculate these travel distances.
You can crop view and make the crop region as big as you want so that you see everything.
@ahirani24 wrote:
@ToanDN
Sorry for being annoying, but this is the error that I receive now. I have been mindful to remove door as an obstacle and keep the others as obstacles. But, unfortunately it is not considering walls as obstacles.
Share your file.
