Error (fatal) when rendering local
2 ANTWORTEN 2
Nachricht 1 von 3
hve-architecten
268 Aufrufe, 2 Antworten
Clipboard01.jpgWhen i tried to render locally i got the following message:
After that Revit says: unrecoverable error occured, the program will now be terminated.
What??? This happend without some windows updates or autodesk installs!!
Where does this come frome???
2 ANTWORTEN 2
Nachricht 2 von 3
mpeperkamp
als Antwort auf: hve-architecten
Hi @hve-architecten,
These kinds of reports are not nice, it should work well.
Maybe the following site can help you further:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Best regards,
Michiel Peperkamp
Cadac Group AEC
Cadac Group
Platinum Partner
Nachricht 3 von 3
Viveka_CD
Hi @hve-architecten
I just checking back to see if this issue is connected to the previous issue you had with rendering?
Link below:
Can you try launching Revit as an administrator and check if this issue persists?
