Hi all,
Have you ever had the following error in revit, when you attach points cloud ?The RCP works in ReCap and also in Navisworks but not in revit 2016 ..Help me please.
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Hi @Anonymous
It could be a special character in your file name that needs renaming.
Please see the link HERE for a resolution to a similar issue.
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
